Dart Big M Block
dart big m block--8.5-1 compression
dart pro-1 heads
scat 4.5 stroke crank
oliver 6,535 billet rods
je piston & rings
crane hydraulic roller. 262 intake 264 exhaust, .680 lift intake
.630 lift exhaust on 114 center line
12 qt. oil pan
2 stage water pump
manley pushrods
scorpion roller rockers
whipple 3.3 blower kit
autronic efi system
msd ignition system
GPM how does this engine ingredient sound:
dart pro-1 heads
je piston & rings
12 qt. oil pan
2 stage water pump
manley pushrods
autronic efi system
msd ignition system
dart pro-1 heads
je piston & rings
12 qt. oil pan
2 stage water pump
manley pushrods
autronic efi system
msd ignition system
I missed a couple, the Big M is an excellant choice, the compression should work well with the Whipple from what I hear. Oliver is a great rod, JE is a good piston, definitely
want good rings. 12 qt pan should also be fine, I think you'll want to add an oil cooler with a thermostat.
