Sell or part out 1,100 HP Motors >
Old 01-13-2011, 03:55 PM
Default Sell or part out 1,100 HP Motors
Looking for some advice on used motors. I have a deal in the works on a boat that already has power in it. Well, I have my own power and don't need the motors but he doesn't want to pull the power. So would you try to sell these things together or part them out? The deal somewhat depends on what they're worth and I have no clue.
Dart Big M Blocks -- seem to have good internals (manley, JE, Jesel etc.)
14-71 Mooneyham Blowers
Dart Big Chief heads
65 hours
Part them out or try to sell complete? Are they worth anything? Thanks you
GOT POWER is offline
Old 01-13-2011, 05:59 PM
Default Fixx
65 hours
i would put them aside and use them for spares,,you never know when a motor is going to pop..
FIXX is offline
Old 01-13-2011, 06:24 PM
From looking thru that classifieds here you could probably get between $ 400000.00 and $ 500000.00 for them fairly easy.
You will need to spend a little $$$ on a good mechanic to check them out for you before they are removed from the boat.
If you could get a copy of the build sheets that would be an advantage and you may even be able to sell them for much more depending on the quality of the internals.
There are currently a pair of Merc 1075's for sale at $ 70000.00 but they are supercharged injected motors.
Good luck.
Fountain Fever is offline
Old 01-13-2011, 07:02 PM
Good luck.
I think ya better recount them zero's !!
picklenjim is offline
Old 01-13-2011, 07:10 PM
nobody in their right mind would pay $50k for a pair of used 1100's. Atleast I wouldnt. You can find a deal on a freshened up pair for that much.
302Sport is offline
Old 01-14-2011, 12:27 AM
articfriends's Avatar
Nobody seems to want used motors except merc's unless you fire sale price them, just the way it is. As far as parting them out, you'll end up with parts you are stuck with unless again, you firesale the stuff or you have top of the line parts, Smitty
articfriends is offline
Old 01-14-2011, 05:17 AM
Lots of expensive parts there. I would try to keep the package together so you could demo the engines to a potential buyer. I believe this would really increase the value. That combo with the big chief heads will require a lot of valve train maitainence and expense. Market will be small for it. However, the heads are in high demand by drag racers, they'll snatch them up. If they'll run try to sell complete, price them right. If not, you'll have an easy time getting some good money for the parts. Just more of a hassle shipping and collecting money.
SkiDoc is offline
Old 01-14-2011, 09:45 AM
Thanks for the replys, I'm assuming I will have to give them away and would rather give them away in one piece versus parting them out. Because of the big chief heads, I may try marketing them to drag racers as well.
I have the build sheets and dyno pulls, so if they leaked down and ran well, anyone have a "give away" number? I know it is all in what someone is willing to give in this market, but with good parts, they have to be worth something. Thank you
Old 01-14-2011, 10:03 AM
Im curious as to what boat your buying. Good luck on the deal.
drpete3 is offline
Old 01-14-2011, 11:06 AM
heres a fresh pair of phaff 1000's w/ trannys for $40k....
http://www.offshoreonly.com/classifi...o36737-en.html
302Sport is offline
