Will Merc 10-qt oil pan work with offshore mounts?
Well crap, as luck would have it, it interferes by about one inch! The boat originally came with a small block attached to this mount. I guess they didn't figure on needing extra clearance with that setup. I'm either going to have to modify the oil pan, or go back to a 6-quart GM pan. I'm not interested in forking out another $400 for an aftermarket pan that might not fit any better.
I'm going to start by removing the lip along the bottom of the mount on the inside, but I don't think that will give me enough clearance. I may have to take the old school oil pan mod method with a 5 lb sledge and a 2x4, but I hate taking the chance of damaging the pan. Cutting and altering the pan might be required.
How much difference will it make running the 6 quart pan versus the 8 quart? I ran the 6 quart on the 461 that was in there before with no oil pressure issues.
Airking
How about trying to find a good used mount here at OSO? Looks like it attaches the same as the bbc mount to the stringer supports. Put ad in the wanted section. I have had pans modified before a good welder can handle it. Or between taking some lip off and taking a plastic hammer to adjust the pan may also work. Just a thought. Eddie can provide a more experianced suggestion I would say.
I'm going to try taking the inner lip off the mount first, and see where that will get me. If I still need more, I might try denting the pan in a little bit at that spot. I have an old junk pan that had a rod go through it that I can experiment with if I need to. Worse case scenario, I have a friend who is a welder who could probably make a minor modification to the front of the sump. Probably cheaper than finding a new mount. Thanks for the reply.
Cut that mount that thing looks like it could hold up a bridge.
Weld the flat stock back in or just take it to a welding shop marked for clearance and have them do it.
Keep the pan size for more oil
Jim
Jim
