my winter project dyno sheet
When you plumbed it the way that I said, did it maintain fuel pressure. If it did, then the pump isn't the problem. If the pump is to small, then the pressure will either not rise at a 1:1 ratio to boost or it will actually back up and the pressure will fall instead of rising.
Eddie
Eddie
