Leak down test, what are good numbers? >
Old 03-28-2011, 11:15 PM
Found a great link on Leak Down test's
http://www.carcraft.com/techarticles...er/index1.html
Not that I plan on doing one myself, but still interesting article.
2Slow4me is offline
Old 03-29-2011, 07:40 PM
is number 7 the common bad cylinder ?
whataride is offline
Old 04-11-2011, 12:27 PM
Does a compression test tell you the same thing as a leak down? If not then please educate.
drpete3 is offline
Old 04-11-2011, 12:37 PM
Default Fixx
Compression test gives you what the cylinders will build in pressure,,a lead down test will tell you the condition of the rings and if the valves are sealing properly..
FIXX is offline
Old 04-12-2011, 11:07 AM
what is the minimum amount of air pressure that should be used for a leak down ?
Old 04-12-2011, 11:15 AM
OldSchool's Avatar
Use 100 psi.....it makes the math really easy!
OldSchool is offline
Old 04-12-2011, 11:36 AM
does less pressure say 32 psi not provide sufficient results
Old 04-12-2011, 12:41 PM
u r gunna need a bigger air compressor
Old 04-12-2011, 12:50 PM
You got a bicycle tire pump your using?
MILD THUNDER is offline
Old 04-12-2011, 02:02 PM
Im looking at buying another boat and the guy did a leak down using 32 psi ..my mechanic will do a 100 constant pressure ..just looking for opionions
