Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 4 of 4
  1. #1
    Platinum Member Platinum Member Mario L.'s Avatar
    My Boats:
    1969 Donzi Corsican 1968 Magnum 27
    Join Date
    Sep 2008
    Location
    Bedford & Wolfeboro, NH
    Posts
    217
    Trim pump set up . .questions
    My boat which is in the midst of being re-rigged will be getting K-Planes added. This is a Magnum 27.
    I am retaining the Volvo 280 drives which have power trim, and have two new trim pumps . .
    As I can't see a time when one would adjust the K planes and outdrive trim simutaneously, why not set up the two new pumps that I have to operate both the drives and the drive trim. I see this as a simple 4 solenoid valves
    all are normally open
    actuate the trim button for the stbd drive and a solenoid for the stbd tab closes . . actuate the tab and the other solenoid to the drive closes . .
    This would eliminate two trim pumps . . . thoughts???
    input please!
    Mario L.
    Mario L.
    1968 Magnum 27
  2. #2
    My Boats:
    77 donzi x18 92 formula 336 sr1
    Join Date
    Aug 2005
    Location
    Between A Womans Leggs in IL
    Posts
    4,553
    Fixx
    Quote Originally Posted by Mario L. View Post
    input please!
    Mario L.
    Mario,,cool idea but i would think their would not be enough fluid to fill the all cylinders unless you have a extra large capacity reservoir tank for the fluid..
  3. #3
    My Boats:
    Join Date
    Sep 2008
    Location
    Posts
    217
    good point, but as I think about it , when would you have drives up and tabs down?
    Mario
    Mario L.
    1968 Magnum 27
  4. #4
    RIPSTA Racing Team VIP Member fireboatpilot's Avatar
    My Boats:
    88/08 32' Hydra Cat twin Bandit 540's, 700hp / 2008 66' Fireboat Independence 4-850hp
    Join Date
    Nov 2008
    Location
    Philadelphia, PA
    Posts
    1,892
    Is it worth the trouble to save about 15lbs? Now if you lose 1 pump you've lost all trim of any sort on that side of the boat and the ability to swap lines to the working pump to power the drive trim or tab to get home. IMO
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
