fuel filters/screens on 454 mag mpi's (where) >
Old 04-12-2011, 02:31 AM
Default fuel filters/screens on 454 mag mpi's (where)
OTher than the water seperator. Where are any fuel filters or screens on a 97 454 mag mpi's. I am so lucky to have the VST's too.. Any help would be helpful.. Thanks
silent lucidity is offline
Old 04-12-2011, 07:23 AM
28Eliminator's Avatar
Mine came with two inline filters mounted on the transom, one from each tank. The fuel pump in the VST tank has a filter on the input of it, that can be changed but you will probably need a new o-ring seal kit, and while you are in there replace the vent diapgram. If you are not having problems I wouldn't mess with it. If you are having problems, I would take the effort to replace the setup. I fired a piston last year due to the lift pump failing and leaned it out. I do have the old VST tank that I would get ride of if you need one!
The parts are expensive and being discontiued.
http://www.mercruiserparts.com/Show_...SEPARATOR+TANK
28Eliminator is offline
