Like Tree7Likes
Distributor Gear Failure on 454 Mag EFI
Old 10-04-2017, 05:18 PM
veloc410's Avatar
My Boats: 2001 velocity 410
Quote:
Originally Posted by veloc410 View Post
Gear is on distributor shaft and camshaft. Camshaft gear may be damaged also. Which means pull the can. You can see if can gear is damaged by looking down thru distributor hole and rotate engine to see th whole gear all the way around it. Something happened don't take anything for granted.
big block is about 800 -900 lbs assembled
veloc410 is online now
Old 10-04-2017, 05:20 PM
My Boats: 290 Aquasport tournament master
Distributor is like brand new. Nothing happened with it while engine doesn't spins it.
I will go in marina later today to do some electrical work and try take some pictures.
Im not mechanic but fixed almost dead engine on my second boat which works perfect now.
caldera is offline
Old 10-04-2017, 05:50 PM
veloc410's Avatar
👍just keep in mind those pieces can cause catastrophic failure. You have to take the oil pan off . And don't flip the motor when you do it .all the pieces will fall towards the top. The new melonized gears come with extra material on them and will most likely be tight against the distributor housing. The gear needs to have about .010 play between it and the small wear plate at bottom of housing. You can do this at home , it takes a little time and finesse but not hard to do. Also there are 2 different diameters you can get. I think it's. 491 and .500
Old 10-04-2017, 06:01 PM
Take oil pan off on the place? Im not sure if its possible but i try to do. At least i will know if there is any broken pc of gear.
caldera is offline
Old 10-04-2017, 06:02 PM
SB
Trade Score: (1)
There where some Crane hydraulic roller cams dozen years ago or so that weren't heat treated correctly and the cam broke right before the cam gear section. So, everything spun but distributor.
SB is online now
Old 10-04-2017, 06:09 PM
veloc410's Avatar
while on engine stand take pan off without flipping engine over. You going to have pull engine
Old 10-04-2017, 06:17 PM
veloc410's Avatar
[QUOTE=SB;4586211]There where some Crane hydraulic roller cams dozen years ago or so that weren't heat treated correctly and the cam broke right before the cam gear section. So, everything spun but distributor.[/QUO
he said distributor gear was gone? Sounds like it broke in half and went somewhere unless just the teeth broke off
Old 10-04-2017, 06:24 PM
veloc410's Avatar
so is distributor gear ok??
Old 10-04-2017, 06:30 PM
Yes without scratches but im going to check everything double before start remival etc..
caldera is offline
Old 10-04-2017, 06:33 PM
veloc410's Avatar
oh. All intact. Gear still on distributor shaft. Maybe just a broken split pin on the gear. It's a shear pin goes thru the shaft and gear
dennis r
0
04-28-2008 06:55 PM
blown formula
31
06-10-2003 06:59 PM
Dave1972
10
09-25-2002 09:44 AM
checkmate981
Checkmate
1
05-06-2002 11:25 PM
checkmate981
4
02-02-2002 01:45 AM
