Port side outdirve & K Plane pump, No Power!
As the title says, my K Plane and out drive pump on my 2000 32' does not have power. The boat has twin 454's if that makes a difference. As a temporary fix a ran a separate (fused) power wire from the batteries to the pumps and it does function as normal. It looks like the power wire is routed towards the transom in loom tubing. Is there a circuit breaker or fuse in or on the engine that provides power for these pumps?
I heard that they may be tied in at the starter, but I'm not sure if there is a breaker there or not? I also posted this on the sunsation board, but I figured this would be wired the same on any model boat with the 454 package so someone here may know the answer
Any help is appreciated
Well last night I figured it out and I should have tried this earlier (feel dumb now). There is a circuit breaker on the transom to the right of the left exhaust tube. After dismantling the cover and unhooking it thinking it was bad, it turns out there is a reset on the side of it, but didn't notice it until I had it in my hand.
I noticed that mounted there and dismissed it since there was not a similar setup on the starboard side, so my thinking was it must have been something for the steering or something that was singular in the setup. Best as I can tell the starboard side must come right from the starter as it is only a few inches away.
Mike
Mike
