water psi bypass >
water psi bypass
water psi bypass
Old 05-23-2011, 09:05 AM
Default water psi bypass
I need one.
30-35psi at WOT
Anyone got one, they want to get rid of? Or where is the best place to purchase one?
thanks
-Shane
cabin fever is offline
Old 05-23-2011, 09:12 AM
JasonSmith's Avatar
Eddie has 2 options for ya:
http://www.eddiemarine.com/store/car...&p=13373&c=238
http://www.eddiemarine.com/store/car...&p=13372&c=238
JasonSmith is offline
Old 05-23-2011, 09:18 AM
I assume you can change the setting by tightening, or loosing the spring inside? Ideally I would like no more then 15#. I have been batteling water in oil issues since I bought this thing, have a feeling my water psi might have pushed a gasket.
Besides the hose, and thru hull, and clamps, is there anything else I need besides this?
Old 05-23-2011, 09:26 AM
JasonSmith's Avatar
Yes, that is how they work. I would get a "T" with 1.25" in and out hose fittings you can put inline on the intake or exit side of the sea pump and then, on the same "T" a weldelet with the appropriate size (1/2") for the pressure valve. You'll need a dump port too.
Eddie has those too: HDT-11403
Old 05-23-2011, 09:29 AM
Thank you Jason, I will get it ordered.
Old 05-23-2011, 01:57 PM
Cheaper From Hardin Marine or CP.
http://www.hardin-marine.com/p-976-w...2quot-npt.aspx
It is really only about a $10 valve marked up to Marine prices.
JRider is offline
Old 05-23-2011, 02:06 PM
figures. I already ordered it from Eddie Marine.
Old 05-23-2011, 02:08 PM
JasonSmith's Avatar
Call them and cancel the order or call them and tell them you found it at CP for less. See what happens. It ain't Wal-Mart, but you never know.
Old 05-23-2011, 03:07 PM
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
This one is Adjustable from 7-25 PSI.
1BIGJIM is offline
Old 05-23-2011, 05:59 PM
Yeah, I have one and it has a Watts stamp and part number. Even at $80 it is way over priced.
JRider is offline
