engine lacking power
How much fuel is in the boat 1/4, 1/2, 3/4?? or more
That or the tank is not venting air in and its creating a vacuum.
My tank has 4 pick ups. I'm going to take the air compressor and blow air down them this morning and see what happens. I just blew down the fuel line with my lungs last night If the issue pops up again I'll try the other set of pick ups. Someday this things going to run right but I'm sure the issue is a fuel issue!
Pull the pick up tube out, and make sure it does not have a crack in it. If the tubes cracked, it will pull air, and loose its prime once the level of the fuel gets down low enough.
Darrell.
Darrell.
