2001 454 mpi timing >
2001 454 mpi timing
2001 454 mpi timing
Old 06-16-2011, 06:41 AM
Default 2001 454 mpi timing
When I hook up my Rinda scan tool and set it to the base timing mode the motor calls for 8 deg. timing do I set it to 8 deg on the balancer or do I set it to zero on the balancer? The timing tool shows 8 deg. when in base timing mode.
dennis r is offline
Old 06-16-2011, 07:57 AM
Unless you have an adjustable timing light then set it at 8 degrees in base timing mode.
soonenough is offline
