Valve cover caps milky after 30 min on hose - condensation or something else?
I have no stats and see what you have there consistently. I don't run the boat very hard to I get that on a consistent basis. it NEVER gets in the oil - my oil always looks brand new after 25 hours.
I had similar issue, after you run the boat take a flash light and look up the exhaust pipes see if the water is reverting back into the minifolds, (you will see the beads of water and how far back they are traveling), i had to extend my inner pipes ten inches.
I saw your thread, and I was totally amazed that you had to do that with those cam specs. My Lightnings have the divorced collectors that have an inner pipe that extends to within about 6 inches of the transom. My cam has 222/230 @ .050 and 114* LSA, so I would be surprised if it would tend towards reversion, but after reading your post, I guess anything is possible. Trouble is, I have muffled tips (Corsa) that do not allow me to look down the pipes.
I added a water pressure gauge, oil Temp Gauge, and Oil thermostat, and Water pressure relief valve, and finally got a 3 day weekend in with no issues what so ever!
What I found out was
1. My oil never got over 150 degrees, so I adeded the thermostat
2. my water pressure was over 35 psi at WOT, so I blew an intake gasket. With the crossover I think the water psi was high enough that the water went through the motor so fast, it never had time to heat up.
Now I finally get 150 degree water temps. after I put the by pass in, and everything seems fixed.
Just in time for the boat to sit in the garage while my son races all weekend. Why the PHUCK do people plan things on holiday weekends?!!!
Pretty sure I got mine from Hardin Marine.
I already had the hose ran from teh previous owner using CMI switchable exhaust (air operated) so I used that line, and bought all the fittings from our local hardware store. At idle or on the hose it barley shows any water psi, at wot Throttle it was up there pegging the gauge.
