Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 6 of 6
Thread: Sea pump HELP..
  1. #1
    My Boats:
    29 Fountain/ Procharged Baja
    Join Date
    Sep 2003
    Location
    Norwalk, Ia
    Posts
    48
    Sea pump HELP..
    I changed the inpeller, housing, and end plate. Running 5 Ibs pressure at 3000rpm and steam is coming out of the exhuast. I was running 15 to 20 pound before. Engine is not running Hot.
    Any Ideas? or what to look for?
  2. #2
    Platinum Member Platinum Member picklenjim's Avatar
    My Boats:
    83' Nordic 23' Viking 505 BBC TRS Drive
    Join Date
    Mar 2009
    Location
    OFallon,Mo.
    Posts
    1,431
    Were there chunks missing from the old impeller. If so you need to find them.
  3. #3
    My Boats:
    Join Date
    Sep 2003
    Location
    Norwalk, Ia
    Posts
    48
    Impeller was 2 season old but all there.
  4. #4
    My Boats:
    1998 Velocity 280
    Join Date
    Oct 2010
    Location
    Cheboygan, MI
    Posts
    543
    Sounds like you may be sucking air. The merc pump housings are crap. I usually spend 1/2 an hour smoothing out the casting marks, and of course porting it.
  5. #5
    My Boats:
    29' Fountain Fever/ HP 500 efi, Whipple Stage 1
    Join Date
    Sep 2009
    Location
    Fort Worth, Texas
    Posts
    71
    I was in a similar sitch. Low pressure, lots of water out the pipes, not getting hot. Ended up being sand, or small rocks blocking the sender at the block.
    If i understood you said, steam but not water, humm? Maybe the system needs to be back flushed, coolers possibly blocked up. usually in that sitch they need to removed and cleaned thoroughly. Ive had that problem also. After that, I installed strainers.
  6. #6
    My Boats:
    Join Date
    Sep 2003
    Location
    Norwalk, Ia
    Posts
    48
    I will back flush but did not have the proplem before rebuilding sea pump, Sucking Air, would'nt the gasket take care of that. Suggestions on porting. I have the old style pump with the 90 degree outlets. Any one ever got bad parts from Mercury like housing spec to loose. I only changed one wear plate would changing the other one help?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
