Vacuum Pumps
Vacuum Pumps
DOES ANYBODY HAVE OR INSTALLED A VACUUM PUMP ON THEIR ENGINE..WOULD LIKE TO KNOW RESULTS //WHAT KIND OF HEADACHES AND SO ON--HAVE TO PUT ONE ON MINE ,SPITTING OUT TOO MUCH OIL AT HIGHER RPM THRU BREATHERS...I KNOW THE MOTOR WILL MAKE MORE POWER //LOOKS TRICK AND ALL THAT..BUT WITH A CRANK TRIGGER IGNITION IM PROBABLY GOING TO RUN INTO PROBLEMS WITH BELT ALIGNMENT OR SOMETHING..LIKE ALWAYS ITS NEVER AS EASY AS ONE EXPECTS..YOUR THOUGHTS ARE GREATLY APPRECIATED..I KNOW I CANT BE THE ONLY ONE THAT NEEDS 1 OF THESE..AGAIN THANKS FOR SHARING YOUR EXPERIENCE AND KNOWLEDGE.. DID I MENTION ITS A B/B CHEVY WITH A BIG CHIEF HEAD..
