Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 7 of 7
  1. #1
    My Boats:
    '77 Hornet II
    Join Date
    Aug 2006
    Location
    IAD/FLL
    Posts
    2,090
    MAG MPI intake manifold options?
    2001 454 MAG MPI, lower manifold corroded. Options I've come up with so far:
    replace with carb (requires a bunch of ignition parts swaps?)
    replace with OEM part(s) from OSO/Ebay
    replace with 500EFI setup (anybody done this swap? Parts interchange?)
    replace with Holley EFI setup
    Perhaps weld up the lower manifold if it's not too far gone. But being a salt water engine I put it far down the list.
    A cam and maybe headwork are on tap for upgrades but nothing radical. Aftermarket exhaust that is Silent Choice compatible might be on the list also. Primary goal is to be running again as quick as possible.
  2. #2
    Charter Member # 55 Charter Member Griff's Avatar
    My Boats:
    32 Active Thunder
    Join Date
    Oct 2000
    Location
    Omaha
    Posts
    12,192
    Get a used freshwater setup off ebay or from the classifieds or swap shop.
  3. #3
    My Boats:
    96 , cig top gun
    Join Date
    Aug 2005
    Location
    sint maarten
    Posts
    1,491
    Quote Originally Posted by Griff View Post
    piece of cake. mine did the same thing. go to the welder, have it tigged up for 100 bucks or less, go to the machine shop and have it faced for 100 bucks or less and you are done.
  4. #4
    Join Date
    Oct 2005
    Location
    Waldorf, Md
    Posts
    523
    z,
    Just fixed one a month or so ago. If it is just badly corroded right at the inlet to the water passage, then it is a piece of cake to weld it up and resurface it. One key to doing the job right is to get a die grinder with an aluminum bit and grind away every bit of corrosion before you weld it back up. Any performance machine shop that does cylinder head porting should be able to fix it for you. Figure in the $250 range.
    Bill Koustenis
    Advanced Automotive Machine
    Waldorf Md
  5. #5
    My Boats:
    '77 Hornet II
    Join Date
    Aug 2006
    Location
    IAD/FLL
    Posts
    2,090
    Thanks guys. Still hesitant to weld on a salt water piece though. Keeping eyes open for a replacement while deciding on a shop. Gotta do some searching for MPI mods.
  6. #6
    My Boats:
    1999 Checkmate ZT280
    Join Date
    Oct 2005
    Location
    Sacandaga Lake
    Posts
    173
    is it the same as the 502 upper and lower? ive got an upper and lower off a 1999 502 mpi sitting in the garage i havent got around to listing for sale yet. PM me in interested.
  7. #7
    Platinum Member Platinum Member ballon78's Avatar
    My Boats:
    96 Hustler 32 w/502 EFI's
    Join Date
    Aug 2009
    Location
    Amesbury, ma
    Posts
    738
    arnt they all brass lined??? everyone i have seen is???
    96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
