Oil pressure drops to zero
Yea, I have plenty of oil in it. The dip stick is one of the side dip sticks that goes in with little angle. I am well above full. It sucks all the oil up into the engine when it is running. Does anyone have any feedback on the T connector and what might be on the other side of the T. My brother has mech oil pressure gauge, but can't reach him, so will have to pick one up. It does look like a sealant was used on the sender.
The dipstick was just an idea. I saw a guy use a "sweet chrome" one that was too long...and showed full when it was almost empty. You said it shows good oil pressure at idle right ? Is that all the time at idle ?
Alarm is not going off, but I am not sure the alarm is hooked up now, as it does not sound when I turn the key to the power on position, which it did with the last engine. Was in it messing around with the wires etc. The way the oil pressure sending unit is set up, it comes out of the engine and is connected to a T type fitting. The oil pressure sending unit is on one side and some other fitting with two wires is on the other side of the T.
When the power is off, the pressure reads between 20-40. Start it up and it goes to 50-60. Review to about 1,000 and it drops to zero. Drop back down to idle and it flickers between 0 and 60. When revving the engine, it will flicker between 0-80. I can't tell if I have more blow by or not. If I stop and restart and stay at idle, it will stay between 50-60.
When I stop the engine and check the oil, the oil is really low, so seems like the oil is getting up into the engine. After a couple minutes all he oil is back in the pan.
so ... when you ran it the first two times and the oil drained back fine, what could have changed to make the oil not drain back now... and where do you think it all could be ? the lifter valley somehow ? thats a lot of oil to put somewhere .. about 500 cubic inches worth of space...
All the oil drains back, it just takes time to show up on the dipstick. Mainly because it does not go straight down and in, but at a really soft angle; about 15 degrees off perpendicular to the engine. Just got a mechanical gauge. Going to get working on it and see what happens.
1 Post
Fixx
1) im with tin,,your pick up came off or
2) do you have screens epoxied in the drain holes in the front,on top of the cam and rear of the block?
3) or are you using 80w90 for oil
I put the mechanical gauge on it and I have pressure. Good pressure. I am guessing the sending unit is no longer good. Not sure if it was a new oil pressure sending unit or not. I was pretty sure I had pressure.
