best water pick up for cat stepped hull
Hey guys any pics of water pickups on bottom or back of cat stepped hull? I think mine on the back is getting a lot of air and water. Just would like to see and here what is working on 120+mph stepped cat with a big blower motor.
Thank u guys!!!
Thank u guys!!!
I used the Teague adjustable thru hull. I mounted it behind the sponson thru the notch. Had to do a little glass work inside the sponson to give the flange a mountng surface but it wroked out sweet.
Nice to be adjustable so you can change water pressure on the big end. Rather than our old school way of just slowly cutting it down. Don't want much in the water it will actually take mph way just want perfect pressure depending on if its for the blower or motor.
There is a different version than that one in the picture might look at both see which will work for you hull better
