Dyno correction factor in Colorado
#41
#42
I can at least respect Vortecpro for coming on here and apologizing for getting a little out of hand, but I have zero respect for a guy that quite obviously has no remorse for pretending to be a cam guru and costing people thousands of dollars, time, and aggravation from trying to use his junk. Did you think enough time had passed that you could slip back in unnoticed?
#43
I haven't slipped back nor do I pretend to be a cam guru. Your coming to your own conclusions. I've had a record year for the past 4 years straight and when it comes to cams I am way up. I don't think that comes from having a bad reputation. I don't think I would have the engine builders that I do using my stuff is that was the case.
I do thank you for the support and using my components in your builds.
#46
Mike,
What do you mean labeled? If you mean what brand name several. Depends on whose box they are going in. I don't do any of the packaging. Items are sold in bulk.
You really don't think every mfg makes every part they list in their catalog do you?
#49
#50
no i don't but if i made parts for any one i would be happey to give the name and what parts of there i supply unless they are junk.
