Mercury 20-40 Full Synthetic now recommended for all engines. Another Oil thread.
minxguy:
Yes, I was not clear. If the SAE weight and API rating are the same, then those specs are the same. But, that does not mean that they offer the same protection in a specific application.
What is not the same is every manufacturers additive pack. The additive packs will make a big difference in suitability for different applications.
it never did,happen...harley pulled that trick on us a while ago,cause they wanted us to buy THEIR oil,and they didnt have any synt. at the time...now that they have one,all of a sudden,the rollers are starting to roll ...i've used amsoil synt. in my customers' h-d for a long time and never had a roller problem...i dont think a roller can slip with 180 lbs of spring pressure....maybe a merc mechanic can chip in...
That's Mercruiser engines. For Mercury Racing engines it still says: "IMPORTANT: The use of non-detergent oils, multi-viscosity oils (other than Quicksilver 25W-40 or a good quality 20W-40 or 20W-50), synthetic oils, low quality oils or oils that contain solid additives are specifically NOT recommended.".
I tend to agree with Pismo. I believe that change interval and filter quality have more effect on performance and protection than the additives. Just my .02
Now, after saying that, I'm NOT confident enough to actually USE that 99 cent WM oil. I still use Mobil 1 full synth. I can afford a couple hundred on an oil change, I CAN'T afford an engine rebuild on one or both engines.
