Difference between a 502/500efi/525efi
The simple answer is no, its a great cam. With different heads and some other changes that cam (525efi) lives in a lot of 600++ HP engines.
The more complex one is that you would till need reprogramming etc to the 502. You can't just do a cam change on any efi engine, and not change the computer
I will be re-programming the whole system anyway when I put the whipple on, so that won't be an issue. I wasn't sure if the stock 502 heads would be okay with the more aggressive cam of say a 525.
Keep in mind that you are going to need to change the rocker arms to adjustable ones, the push rods, and the lifters
