Tow vehecle
I would not do it! I had to make an emergency tow this past weekend with an 08 1500 4x4 chevy. It did okay, but I knew my stopping distance would have been huge. We were on rural roads, and I kept my speed down and planned ahead. Not a good tow rig for that much weight on a regular basis. Just doesn't like it. The little 5.3 was working it's guts out.
No way. Some mfg's give their half-tons tow ratings over 8,000 lb, and it's just scary. No matter what the marketing is, get at least a 2500 hd for towing 9-12k, and 3500 for anything more.
They can't hold the tongue weight, and the hitch/frame mounts aren't intended for a 12k load. A half ton might pull 9-10k ok using a fifth wheel, but not on a drawbar.
Imagine trailer brakes failing down a hill and all you have left is your little sissy half ton brakes and a 5 liter gas motor for engine braking...
Don't confuse the ability of a truck to be hitched up to and move a load with actually being able to safely "tow" it at highway speeds.
Had this happen to me once with "only" a 8K tow. No fun. Rotors and pads were instantly turned to junk. Everything was so hot I was afraid it melted the caliper piston seals.
1 Post
You'll as a minimum need a 3/4 to tow safe.
Just a few numbers.
A 25OL is 4750 lbs. dry + 96 gal. 592 lbs. + battery and stuff 50-75 lbs. + trailer at least 1400 lbs. = 6800 lbs.
A 33OL is 7500 lbs. dry + 185 gal. 1142 lbs. + batteries, some water in the 9 gal. tank and stuff 150 lbs. + trailer at least 2300 lbs. if a twin axel = 11092 lbs.
It'll most likely be even more. I've never seen a dry boat that was lighter than the manufacture claimed.
I think everyone who commented summed it up pretty well, another thing to think about is I would not want to get pulled over by the DOT the ticket & tow would probably cover a couple insurance payments for boat & truck.
1 Post
My parents have "RV'd" for years, so, I grew up around towing, and I agree with what some others have posted, some of the stuff you see going down the highway is actually terrifying, just because you can "move" a 28ft cabin trailer [or boat] with your 20 year old S-10, doesn't mean you can haul [or stop!] it safely.
We are only an hour or so apart and I boat near you, and in the summer when the "blitzes" are on by the OPP they pull a lot of trailers/boats over to check both the truck and trailer, kinda suck if you got stopped on a Friday of a long weekend and had your stuff impounded for the entire weekend, plus the tickets, AND you will have to upgrade your tow vehicle before you tow again anyway.
I moved my 24ft outlaw with an 02 1500HD 4x4, the boat was on a tandem axle aluminum trailer, it was TERRIFYING when a stop light would change to "yellow" and I had to try and stop quickly before the intersection. This truck was used by my father to tow his 5th wheel RV and was TOTALLY set up for towing. I installed brakes on both axles and now I dont mind towing, but, I would never pull a 33ft boat with it, and it has the 6.0L motor and all the HD options.
Forget the dually, go for broke and get a F-550 or F-650 and never have to worry about what your gonna buy/tow again. [-:
Michael
Michael
1 Post
Michael
Michael
