How to winterize 496 with boat floating in water all winter? (no lift, no trailer)
In the past my boat has been kept on a lift through the winter but I sold the lift when I sold my house. I do not own a trailer. My normal winterization for my 496MAG has been: use Merc quick drain air pump. Unscrew 4 blue drain plugs to make sure all water is drained. Pull end caps off of heat exchanger and blow it out.
My boat will have to spend this winter floating in a slip. I hate it but that's just the way it has to be right now. The lake is clear fresh water and gets down to around 50 degrees in the winter so the water doesn't freeze. I tried my normal winterization procedure last weekend but lake water just continues to enter the cooling system when I use the quick drain or unscrew the blue drain plugs. Water even creeps back into the heat exchanger after I blow it out.
What is the best winterization procedure for a 496 powered boat that is floating in the water? It seems that I need to pour anti freeze into the raw water side of the cooling system but where should I pour it in? Thank you guys for your help!
I believe the only way you could do this would be to put a ball valve between your transom assembly and the sea water pump. This would be the only way to ensure that lake water does re-enter the engine and dilute the antifreeze.
Or buy a purpose built bilge heater, with a backup power supply.
What kind of boat is this?
1 Post
Another method I've seen used, but not as effective, is simply to put the muffs on the drives while in the water and run fresh water on a hose. Then connect a tube, as large in dia. as possible, with a big funnel in one end and the other end to the muffs. Have one at the ignition and have one or two to help you on the stern end of the boat. Pour AF into the funnel as fast as possible to create a steady flow of AF to the moter. This is also why is important to have someone at the ignition, if you can't get the AF into the funnel fast enough.
I like to use this one. AMSOIL Antifreeze & Coolant
When you got the hose off the RWP, you could do a permanent flushing system with ball valves as Sydwayz suggested. It'll make things super easy and safe in the future. Nice little winter project.
Thank you guys for the suggestions! I really appreciate it.
The boat is a 2001 Formula 260BR. The dock where I am keeping it now has shore power and I have an onboard charger for my two batteries. The boat also has two large bilge pumps so I feel pretty secure in leaving it in the water. It's close to me so I can check on it often.
I like the idea of blocking the raw water inlet hose. Could you guys explain to me which hose that is? I'm thinking its a 1.5"ish hose near the starter (starboard side of the engine)? Thanks again for the help!
1 Post
No matter what, when you have it off, install a fresh water flushing system. You won't regret it.
I bought two ball valves and a T with a garden hose adapter for a similar reason...mine was to flush out saltwater while still in salt water. Also going to hook a 5 gallon bucket with a short hose full of antifreeze prior to putting her up for the year. Only cost a few bucks...I hate muffs.
1 Post
Unhook the raw water heavy walled hose coming up from the drive from the raw water pump and lift the end up well above the water line and plug it. No more water coming in. Winterize as usual.
