need an oil cooler???
If you wanna get fancy, you can wire a temp sensor above the oil filter pad(after cooler) and another one say at the filter head(before cooler, if plumbed that way). Run the sender wires from both senders to a toggle selector switch, then one wire to your temp gauge. This way you can check oil temp before and after the cooler by flipping a switch.
thanks foro all the info and advice fellas
