Fuel system setup
Fuel system setup
How much HP would this setup support.
1/2" tank pickup, 5/8" fuel line to Fram racing fuel filter, #10 line from filter to 1/2 NPT inlet on Holley 130 GPH self regulated six valve mechanical pump. 1/2 NPT pump outlet to #10AN line going up to four port fuel block. Then #6 line to each carb bowl. Dual 850 Holleys on top of a 420 B&M blower.
Trying to keep a simple fuel system but with large lines and no 90* adapter fittings.
Your GPH will only flow as much as your smallest line. I think the 1/2 is good for roughly 130 GPH free flow and here s a quote explaining how to calculate what you'll get. You can play with the numbers in the formula below.
The average advertised weight of a gallon of premium fuel is 6.34 lb/gallon.
Brake Specific Fuel Consumption or B.S.F.C.
Brake Specific Fuel Consumption or B.S.F.C. is the amount of fuel required to produce 1 HP for 1 hour. This means that an engine with a B.S.F.C of .5 will burn 1/2 or .5 lbs of fuel to produce 1 HP for one hour. Determining exact B.S.F.C for a specific engine is complicated and requires an engine dyno.
Based on industry standards the B.S.F.C for:
Normal Aspirated Engines is .45 - .55
Supercharged Engines is .55 - .60
Turbocharged Engines is .6 - .65
need to calculate fuel required:
Target Hp * B.S.F.C. = Fuel required in lbs/hr
600 *.56 = 330 lbs/hr
Most fuel pumps flow rate is advertised in gallons per hour:
Lbs/hr / fuel weight per gallon = gal/hr
330 / 6.34 = 52 gal/hr
but remember pump losses, and a fuel pressure regulator and a return line fuel feed system designs flow requirements ?
I have an LED on the dash that blinks if psi drops below 4psi and I have mechanical gauges mounted on the engine. You can see them in the big plate that holds my MSD,coil, etc.
I have a similar setup on my boat, my concern is sucking through the filter. Is it better to pull through the filter or push through it? I have been thinking about using a mesh prefilter to the pump and then push through my final filter. I am using a WIX 3522 filter which has a built in water separator and has twice the filter area of the standard Fram. Interested in any opinions, I'm running about 700hp through the Merc seawater pump, and I know I'm at the limit of this setup.
Eddie
