Safe Guards to avoid reversion/ingestion
1 Post
These are the mufflers we have now.Tested with dB meter at the dock,barely passed the 85 dB .
http://www.youtube.com/watch?feature...&v=QtMEmWhSRJo
Inside without the engine box. Loud!
http://www.youtube.com/watch?v=6L-st0izosU
Friend built his 34' boat a few years ago with a single engine in mind.We've opted for the ZZ572 engine with Stellings dry exhaust.It worked great until the inner jacket at one of the exh flange cracked and doused the exh valve and dropping it.We had to scrap the dry exhaust idea and had Eddie Marine fab a s/s wet one to our spec, mounted on the EMI aluminum unit.We had to get the risers taller than the stock units readily available to stop reversion. 500 hrs on the engine and boat ,running top as a commuter on weekends.
Original setup
Present setup
Original setup
Present setup
Sorry Baywatch
Geronimo36
Flappers will help with water ingestion when the boat is sitting at the dock/mooring and waves come over the pipes but they will not help with reversion while the engine is running.
If you have gills, I really think you're fine Josh. Your cam is smaller than the 731 the HP 500's had and they were built originally with Gils and silent choice.
http://www.cranecams.com/product/car...detail&p=24282
1 Post
My friend used to work at Soverign Yachts now Richmondyachts in Richmond B.C [ http://www.richmondyachts.com/gallery.html ] where he started the boat from scratch.He was a foreman there and did the interiors. He also worked on Dennis Washington's Attessa when that was stretched in Vancouver
.He used a windshield from a SeaRay for his boat, rest of the boat is a one of.
You can see more info I put on at >
http://www.riverdavesplace.com/forum...ead.php?t=4456
