525sc wiring diagram? >
Old 03-22-2012, 07:06 PM
Default 525sc wiring diagram?
I'm ready to test run my 525sc engines on a test stand before reinstalling them but the wiring diagram I was going to use does not match my engines. Can anybody tell me which terminals in the main connector on the back of the engines will be for starter sol. and ignition system power?
JD33 is offline
Old 03-23-2012, 02:06 AM
Received 1,826 Likes on 911 Posts
Purple wire is for key on/ignition.
Griff is offline
Old 03-23-2012, 07:36 AM
Yellow/red tracer = start
Purple = ign power
Blue = oil press
Tan = water temp
Tan/blue = alarm (water,oil,drive lube all same)
Brown/white = trim sender
Red = power
Black = ground
Needs to be plugged in to work as power from starter lug feeds the ign switch
Unlimited jd is offline
Old 03-24-2012, 03:29 PM
Thanks guys, there ready to test run.
JD33 is offline
