how many psi on a blower you need to make 750 hp out of a 502 bbc with 525 hp
I was just wondering, i have 502 bbc motors making around 525 hp and looking to get around 750 out of em. With a 671 blower and no intercooler how many psi would i need. And would motors still be reliable
its go be carb and the heads are iron wit a little work done to them as far as the cam i dont know would have to call innovation marine
i just looking roughly 8 psi would give how many more hp
The Illustrious One
I believe a rule of thumb with everything coinciding with one another (carbs, cams, heads, and so forth) its about 30 hp to 1 lb of boost.....I THINK....that's what I remember to get to 1250 from 800 which was also an Innovation Engine!!!!
Dying,....Is the day worth living for!!!!!!
HP per each boost psi is always going to be the biggest just into boost. IE: Your 1st 5 pounds will be more hp per psi boost than say going from 10-15psi.
Edit in: Each psi and each hp per psi is 1 million % dependent on engine size and build and SC and intercooler effeciency and so on and so on.
