Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 6 of 6
  1. #1
    My Boats:
    Donzi ZX
    Join Date
    Jun 2011
    Location
    Cashiers NC
    Posts
    444
    oil filter location KE exhaust
    Where and how do most people relocate their oil filter when installing Keith Eickert exhaust? Factory location was on/above the port side manfold. Engine is a carbed 454 mag.
  2. #2
    My Boats:
    77 donzi x18 92 formula 336 sr1
    Join Date
    Aug 2005
    Location
    Between A Womans Leggs in IL
    Posts
    6,321
    fixx
    Quote Originally Posted by tnc110 View Post
    a you could make a bracket and mount it on the rear part of the cylinder head or find the housing that mounts on the back of the head...i have one i can part with but you will have to have new hoses made.
  3. #3
    Gold Member Gold Member endeavour32's Avatar
    My Boats:
    1989 Formula 292 SR-1
    Join Date
    May 2009
    Location
    Chicago, IL; Onekama, MI
    Posts
    3,032
    As mrfixxall said, mount it to the back of the block... That's were I mounted mine when I ran Eickerts!
  4. #4
    My Boats:
    Donzi ZX
    Join Date
    Jun 2011
    Location
    Cashiers NC
    Posts
    444
    silly question...how much oil is going to come out of the oil lines when I pull them to get new ones made?
    Also, a question about the tails. The Eickerts are staggered an inch or two to the side from where the OEM manifolds were. I bought these things used and they came with LONG tails. I am going to cut them down. I would like to keep the tails as long as possible, but am concerned with the offset and kinking the rubber exhaust hose. Any thoughts.
    When I cut the tails, they will probably only be about 6-8"s long...do I still need to weld in a spacer between the inner and outer pipes like the long tails had.
    Thanks for all the help fellas!
  5. #5
    My Boats:
    WARLOCK EURO24
    Join Date
    Aug 2009
    Location
    CONCORD, CALIF
    Posts
    407
    I relocated and upgraded most of my oil system last year. I picked up an hp6 filter head and billet bracket that mounts the assembly to the back of the port cylinder head. I also changed all the oil cooler and filter hoses to the summit -12 push-loc hoses and fittings. The hose and fittings are priced pretty reasonably and are not as restrictive as the stock stuff.
  6. #6
    My Boats:
    Donzi ZX
    Join Date
    Jun 2011
    Location
    Cashiers NC
    Posts
    444
    update:
    cut and welded an aluminum T- bracket that mounts to the the port side manifold to hold the oil filter. Also had to make a plate for the fuel filter on the starboard side, so that I could slide it forward (no clearance)
    Might have to get a smaller belt for the alternator, it looks like it is going to interfere with the first tee on the underside of the headers.
    This has turned into a real PIA...never though there would be so much involved to get this to work.
    Also have to get a new oil line and fuel line.
    Can't wait to hear them though!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2017 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
