Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 3 of 3
  1. #1
    Registered onesickpantera's Avatar
    My Boats:
    1999 Pantera 24 Sport
    Join Date
    Feb 2005
    Location
    Michigan
    Posts
    3,324
    Oil pressure at block vs filter pad
    I want to mount a mechanical gauge on my engine for peace of mind. I mounted it where my sensor is(above the stock filter location on the block)and it read 45 lbs. I then mounted it in the remote filter pad and it read 55lbs.
    Is there a reason it would be higher at the remote pad? I was thinking it has something to do with resistance from the oil lines but shouldn't that raise the pressure a bit everywhere?
  2. #2
    Offshoreonly Advertiser Offshoreonly Advertiser Young Performance's Avatar
    Join Date
    Jan 2004
    Location
    Tennessee
    Posts
    3,516
    You were probably reading it before the filter in the remote filter mount. When reading in the block, you are after the filter. As the oil warms up, those 2 numbers will get closer to each other. Warmer oil flows easier through the filter.
    Eddie
    Truly custom built EFI and Carb. engines from 500 to 1500 HP. Also specializing in outdrive upgrades and repair, custom rigging and fabrication. We can handle all of your performance boating needs. See a sampling of our engines at www.YoungPerformanceMarine.com Contact us at 615-216-7449 or youngperformance@comcast.net Like us on Facebook at https://www.facebook.com/YoungPerformanceMarine
  3. #3
    My Boats:
    Join Date
    Feb 2005
    Location
    Michigan
    Posts
    3,324
    Quote Originally Posted by Young Performance View Post
    Eddie
    Ahhh, I didn't realize that the block was measuring after the filter. But, if I put the gauge in an "out" port in the remote filter pad shouldn't that be reading as it comes out of the filter? Maybe the additional oil line and oil cooler lower the pressure at the block when the oil is cold?
    Thanks Eddie.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
