Please help! Power steering pump alignment
Please help me figure out how my power steering pump is supposed to be mounted on my 454 gen VI. I have 2 different brackets to choose from. One looks to be an imco relocation bracket and the other a merc stock bracket. I will attach pictures. I will also attach picture of the back side of my pump. First off, it looks like I will need some spacers to install it, but I don't see any such spacers in the parts diagrams on mercruiserparts.com. If spacers are not used there is no way to mount the pump because the black "return tube" would hit the bracket. (see picture) The pump and bracket are off the old engine that was all apart when I purchased the boat. The stock bracket came with the gen vi motor I recently purchased. Both brackets have the same problem so I'm thinking it is the pump or the pump studs or missing bosses. If I use the homemade spacers the last guy used, the pump is not aligned with the crank pulley. It does not extend out enough. It is about 3/8 inch in from where it should be when I put a straight edge across the crank pulley. I'm wondering if my pump is not the correct pump? Can someone give me advice please or post a picture of the backside of your PS pump.
Thanks. I was thinking it is my pump that is the problem. Does anyone have a pic of the back of a PS pump that would fit? If you notice the pump has a tube coming right out the middle of the back side of the pump and is routed along the back of the pump. So there is no way to mount the pump without spacers. If I tried the tube would hit the bracket. I'm guessing my pump is not a stock pump?
