525 Seawater pump lube
Oil and gas is a lousy lubricant. It is best to chage the oil, probably more than once a year.
Ken
I find it easier to just remove the fuel pump from the sea water pump and use my Jabsco oil sucker to remove the old oil and replace with Amsoil Extreme gear that I use in the drive. The Amsoil seems to handle the dillution well. As a matter of fact my level never changes and I don't have any leaks, so I am assuming the fuel leakage is only enough to add an odor to the oil as the viscosity doesn't seem to be altered either. It may be much ado about nothing at least for me.
I just pulled my sea pumps and changed this oil as all have discussed. With it on the garage floor I filled the reservoir with a little medical 6cc syringe. I filled it to the "bottom" of the threads while looking from above. Now a nagging fear just popped into my head... Is there a possibility of putting too much oil in the reservoir?? I didn't measure, I just "filled it up" while the pump reservoir was lying horizontal on the floor as opposed to vertical when it is mounted on the motor. Thanks for any replies.
