7.4 MPI (1998) fuel line fitting to fuel rail specs?
I'm building a fuel line and I do not have the original. It appears to be a metric 16mm x 1.5 o-ring fitting. I found this connector but I'm not sure...
http://www.summitracing.com/parts/AER-FBM2608/
Does anyone know if this is the right fitting or if not then what are the specs that I'm looking for.
Thanks in advance!
Thanks in advance!
Just in case anyone is searching for this i figured it out. i was correct, the fitting is 16mm x 1.5 o-ring. The aeroquip fitting link above is correct or you can save a couple bucks and get the same fitting from Russell Performance at Summit.
Now on to final installation of a 600hp procharged 7.4 MPI
