Ok, so how many of you guys are running automotive carbs, be truthful.
Chevy-Harley fan
OK...with a starter you CAN blow your a$$ up!!! Gasoline fumes and a sparking starter don't mix...you might as well throw a lit match in the bilge. Besides all that...they won't last very long at all...automotive starters can't tolerate a marine environment and rust up quickly.
If you HAVE to use an automotive starter for Gods sake vent the bilge with an open hatch and blowers running!!
Pete
Pete
When I was building my engine I made sure that I ordered a marine carb and fuel pump. Starter is also marine. To hell with all the legal issues, I would feel terrible if I hurt my kids by being a cheap ass. I don't know the differences in the street and marine stuff and really don't care, there is a difference for a reason and I want to make sure everybody is as safe as possible
I have had marine carbs apart, saw no difference in throttle shafts, no seals, etc...only the finish(painted) pcv plugged and J tubes on the holleys, not used on Q-jets or the webers aka edelbrocks....calibrations are the only real difference
the trottle shafts are teflon coated(green coating on Q-Jets) orings or teflon sleeve/sprial rings, this is to prevent backfire from going out throttle shafts. the marine components used to have rigerous testing in lower to upper explosive limits in test cell. what may look simple has been tested to minimize flame front travel. most racing carb shops seem to use the same throttle shaft setups as marine carbs, helps control a/f metering flow. metering blocks will have larger fuel passages, thats why modified racers are after rochester 2gc's all the time.
The marine carb will not let gas past the seals on the shafts, as well as dumping gas back into the intake in the case of a stuck float. Legality aside, it just isn't worth the risk to your family and friends to explode or burn over a couple hundred dollars. If something bad happens and you could have prevented it with something as simple as a approved carb, you will surely wish you had done so . I don't have the slightest idea how litigious Canada is, But you can be sure that if you are sued, and you don't have approved equipment, you are totally and thoroughly screwed, in both civil, and possibly criminal courts. If you do it right the first time, you won't regret it as you are doing it over the second time.
Do you want to worry about it, or not? That's really up to you.
besides the J tubes if it is truely a marine carb they have some air bleed holes inside slightly enlarged. Also the throttle shafts have a channel cut in them before they come out through the body of the carb so fuel can't run out between the body and shaft.
Where does one find a 950CFM or larger marine carb? I've been told by several high performance engine builders to stay away from J-tubes as the air velocity going past can change the fuel height. I have a Pro-Systems 950 that has a piece of Tygon tubing connecting the 2 vent tubes that extends up away from the carb with holes in it. Pro-Systems builds carbs for blow through applications so they know how to build a sealed carb.
To address the differences between automotive carbs and marine carbs, I submit the following:
http://www.uscgboating.org/regulatio...rds_partf.aspx
These are the USCG regulations which govern marine carbs and their associated tests to make them marine-worthy. You can perform the modifications yourself, and be in "compliance" for your own peace of mind, but it will never actually replace the certification itself - which is what you'll need in case something ever goes wrong and the blame is placed on non-approved, non-marine-grade equipment.
MarineKinetics
I would caution against the use of J-tubes/ inverted orifice vents in any carbureted application. With the J-tube extending into the airstream, as air speed increases into the body, pressure at the inverted opening decreases. The pressure drop is transferred to the surface of the working fluid in the bowl. Proper fuel metering is dependent upon the correct differential at the bowl vs. the opening at the jet. The imbalance can result in incorrect mixture distribution. Ideally you would have the pressure at the working fluid (vent tube) stable relative to atmospheric allowing the jet orifice size to properly meter the fuel dependent upon the pressure drop in the venturi. The use of the J-tube can potentially result in a top end lean condition.
If you have concerns regarding issues with the CG or insurance carrier the balance tube pictured below may be a preferred option.
Bob
Bob
