O₂ Readings: Naturally vs. Super Charged
Do you really get a cylinder to cylinder or bank to bank difference in AFR with a port injected EFI motor?
It would seem that each injector, with the same BPW, off the same sized/length runner would have a nearly identical AFR.
I can see that with a carb or TBI setup or just spraying fuel into a large plenum but not with port injection.
Interesting conversation, so on my 502mpi with aluminum heads and a side mount whipple at 6lbs of boost, my wide band says 10.5 WOT. From what is being stated I am to rich. Should I put the next size smaller pulley on and check it then to lean it out some to try and get to 11.6 - 11.8 AFR? Or try to lower the fuel pressure to lean it some?
