Water pressure relief valve placement? >
Old 07-28-2012, 07:56 AM
Default Water pressure relief valve placement?
Where are most people putting water pressure relief valves? Are you putting them off the sea strainer or are you putting them after the sea pump?
GS42fun is offline
Old 07-28-2012, 10:31 AM
Rookie's Avatar
Received 1,206 Likes on 579 Posts
I am putting my relief after my cooler but before my block. I still want the volume of water to go through my cooler.
Rookie is offline
Old 07-28-2012, 07:38 PM
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Most people with strainers run them before.
1BIGJIM is offline
Old 07-29-2012, 08:01 AM
I am thinking about putting my after the coolers, but before the block also. I was wondering if it is put before the strainer do you need to wory about stuff getting into it and plugging it?
Thanks for the replies.
GS42fun is offline
Old 07-30-2012, 02:48 AM
I just installed mine when I did my new motor. Mines after the cooler but before the crossover inlet. I bought the valve from a guy here on offshoreonly and the 1 1/4" valve fitting from CP Performance.
mustangmark is offline
Old 07-30-2012, 10:06 PM
Put them after the sea strainer or you will get debris in them!
catman01 is offline
