how to backflush a 496 ho
1. Change motor oil
2. Change gear oil
3. Change impellor.
This way you have some kind of maint. baseline. Those 3 things are pretty easy to do yourself.
great advice! i will do and also change the plugs and do a compression test.
If the one pick up is feeding the inner cooler and the motor it could be, the water is going to take the path of less resistance, which would rob your motor. Just a guess, I have a whipple as well and I had to reduce the water going into the cooler so my motor would get more water flow. What kind of whipple set up do you have?
