454 MAG MPI issues. Won't rev under load. >
Old 04-16-2014, 07:14 AM
Yes. While youre in there, check the fuel pressure coming off the high pressure pump's discharge. You want 37 psi.
Cole2534 is online now
Old 04-16-2014, 08:00 AM
Perfect, thanks Cole.
seansmp8 is offline
Old 04-16-2014, 01:50 PM
Anyone have or know someone with an extra VST they would sell? I'm not sure if it's done or not yet but I figured I'd line one up.
seansmp8 is offline
Old 04-17-2014, 10:19 AM
Do some thread searching, there are much better options
Old 04-17-2014, 01:30 PM
I had a similar problem with one of my 502 mags turns out it was a bad coil still ran fine when not under load but when loaded up it had no power. no miss while running either. it had to have been missing while getting on plane but i couldnt hear it....
Yoda_Man is offline
Old 04-17-2014, 01:56 PM
Charter Member #1171
obnoxus's Avatar
Does it feel like a rev limiter,,,, or just no power?
Gonna sound silly,,,, but unplug your gear oil reservoir bottle sending unit
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 04-18-2014, 08:13 AM
Yoda, I will check into that for sure. I plan on doing a complete tune up this weekend (Cap, rotor, wires, plugs), I think I'll go ahead and throw a new coil on there. Obnoxus - I have hear of that sensor going bad and not allowing the motor to rev up, will unpluggin it simply bypass it?
seansmp8 is offline
Old 04-18-2014, 08:26 AM
obnoxus's Avatar
correct, unplugging bypasses it,,,, you NORMALLY get an alarm along with it,,,,, but its worth looking at
obnoxus is offline
Old 04-18-2014, 08:35 AM
28Eliminator's Avatar
A few years ago I help a friend change head gaskets and install a procharger on his 454mpi. It idled and ran find on the hose but once it was in the water under load, it didn't have any power to get on plane. after hours of messing around with timing, plugs, wires, cap, and troubleshooting, we found an injector plug didn't get snapped all the way on and was just sitting under the plenum. Plugged it back in and bingo, it ran great. Not saying that is your problem, but just one bad cylinder or injector can cause way more power loss than you would think it does and it may not sound like it is missing. I believe just unplug your gear oil reservoir bottle sending unit to bypass it. I do have a VST off a 96 or 97 454mpi if you really want to go that route. It hasn't been on a boat for 10 years, but worked fine when it was removed.
Problems like this are a pain to find, so Good luck and don't sink the boat!
28Eliminator is offline
Old 04-19-2014, 08:53 AM
the only way i found my issue was swapping parts one by one from the other motor. was a msd coil now i carry a spare
Yoda_Man is offline
