Rod main bearing looking bad after 80H
1 Post
Fixx
Before to looking at the worng place i have tear down the engine due to a melting piston by pre ignition on cylinder # 6.
I can not belive is that thing have make contamination in the oil, If anything happen the oil should be filtered before got the main and rod bearing.
I dont think that is the piston aluminum particule got into oil and make this.
What did you think?
What did you think?
dude you come on here asking about bearings then all the pros on here state their openion now you say you melted a piston????????????????
Its most likely from your rings or the ring carving at the cylinder wall....what a waste of peoples time and posts...
I realy think that is not the melt piston do that but as i said i am not an expert to know what is realy happened to the bearing.
I think oil heat and oil cavitation can do that
What did you think?
What did you think?
I am rebuilding an engine now with a burnt piston. I have some bearings that look just like that. The oil was sooty from combustion gas and the oil was rather over heated looking/smelling. That is what I attribute to the bearings that look like this.
I must say that melting the piston, will contaminate the oil! I feel we have been playing a guessing game here and wasting time. I don't care what you have for a oil filter, small micron or large, the small silica from the alum. burning away is going to most likely pass the filter or when the by-pass opened. Sorry to say; but I DO NOT SEE SCRATCHES IN THE BEARING, only embedded particles. Why did you melt the piston?
I ran 9 psi boost with b&m 250 blower with foward ofset carb plate, 7.5:1 comp ratio / performer rpm marine aluminim head i have run all the sumer long with a meth injection system with an afr between 10.5 to 11. During the fail test i run without met inj and my afr go up to 12.5 wot.
The piston # 5-7 no sing of pre ignition but much more leaner than the # 1-3 and the # 6-8 have sing of pre ignition (# 6 melt) also much more leaner than the # 2-4.
I have also fond a blown head gasket between #6 and 8 cylinder as i can see on the cylinder block.
Pic of the melt piston and better of the bearing:
Fast Singles Club
I think i melt the no.6 piston due to a bad fuel distribution setup and during an engine test, the no. 8 have sufer also of pre ignition.
1 Post
fixx
