Can I eliminate a couple of these gauges? old race boat.... >
Old 10-24-2012, 09:21 AM
Registered User
Default Can I eliminate a couple of these gauges? old race boat....
Some of you have seen my restoration thread, notice my dash has 18 gauges in it. My question is should I or can I eliminate some of the less important ones?? I am trying to clean it & make it less cluttered.
It has:
2x Oil pressure
2x Oil temp
2x Water pressure
2x Water temp
2x Fuel pressure
2x fuel gauges
2x Volts
Then RPM & MPH
GTOKILLER is offline
Old 10-24-2012, 10:15 AM
Registered User
Originally Posted by riverrat
less important ones ? lol
keep em
Jeff
Yea I know just didn't think more boats used fuel pressure, water pressure some probably don't have oil temp??
Old 10-24-2012, 10:22 AM
Rookie's Avatar
Received 1,207 Likes on 580 Posts
A lot of boats don't have them, but those are all the gauges that I added.
I would also hook up the kill caps.
Not throwing stones cause I just added those this year myself.
Rookie is offline
Old 10-24-2012, 10:47 AM
Registered User
Oh they are hooked up just need the tethers to attach them to me. I cranked the chit out of it at the dock one day because I knocked on off with out knowing.
Ok I think Ill probably keep em all. More is always better just don't like the dash, its all white vinyl. Just waiting on to get me gauges back from Livorsi.
Old 10-24-2012, 11:56 AM
Keep all because the one you eliminate would be the one that could have saved you a lot of $$$$$$.
sonicss42 is offline
Old 10-24-2012, 12:57 PM
In a race boat they were there for a purpose.
In this case its function over form.
f_inscreenname is offline
Old 10-24-2012, 08:46 PM
one option would be digital guage that rotates between readouts, reduced footprint. some options put fuel guage on engine with alarm light on dash. voltage could be mounted by batteries. input overload,; too many guages mounted low takes your eyes off infront. to me best would be display on dash under windscreen. just some thoughts.
keith2500hd is offline
Old 10-24-2012, 09:28 PM
I know its not the direction you are looking for but I added a Amp's guage. With twin motors feeding both batteries its nice to know if one Alt is dieing or not.
Old 10-24-2012, 09:39 PM
That's one of those things that it is nice to know, but rather rare and more than likely the other can compensate enough to get you home.
Captain YARRR is offline
Old 10-25-2012, 04:48 AM
boatme's Avatar
The water pressure gauge is fist line of defence from overheating It tells you if you have sucked up somthing on the intake and will alert you before the temp gage does
Keep em all
boatme is offline
