What bearing to run for 489 build
your right, does not matter what rods, and does not matter forged vs. cast crank, I love when the non engine builder guys chime in since both of them answers were wrong... the oil film is between crank and bearing, in reality they never touch...I have cast cranks with coated H-series on rods and mains..my rods are also forged 420 rods.
I like the coated bearings and always use them, when you have fails they can save you, I had a fail, cracked a cylinder wall and contaminated the oil with lots of water, did ZERO damage to bearings and actually reused them and 5 years later all is well, they had looked like they were never ran...
H Series - Best to start with when unsure which bearing to choose
Medium level of eccentricity and high crush
Enlarged chamfers for greater crankshaft fillet clearance
Made without flash plating for better seating
Use with crankshafts that have oversized fillets
Use with engines that run mid-high RPM range
Contact patterns should ideally cover 2/3 to 3/4 of the bearing surface
P Series
Typically the greatest level of eccentricity
Rods and mains have high crush for maximum retention
Most are fully grooved to maximize oil flow to rod bearings
Reduced overlay thickness to prevent overlay fatigue
Use where extremely high RPMs cause severe rod bore close-in
Use where higher eccentricity is desired to narrow bearing contact patterns
V Series - This series essentially duplicates Clevite's former Vandervell parts
Typically low to medium eccentricity
Not available with oversized chamfers
No flash plating on the steel back
All Clevite main bearing sets use a single-piece thrust bearing
Narrowed parts available to accommodate increased crankshaft fillet clearance
Lead-indium overlay offers slightly better conformability
Part Number Key
H - High-Performance
HD - High-Performance bearing with dowel hole
HK - High-Performance bearing with moly/graphite coating
P - Standard Clevite 77 tri-metal bearing
N - High-Performance Narrowed for greater crankshaft fillet clearance
HG - High-Performance full angular grooved bearing
V - High-Performance with Lead Indium overlay (On Main Sets this indicates partial groove also)
VG - High-Performance with Lead Indium full angular grooved bearing
D - Bearing has a dowel hole
K - Tri-Armor coated bearing
X - Bearing has .001 more oil clearance than standard
XX - Bearing has .002 more oil clearance than standard
A or AL - Indicates Aluminum bearing material
P Series
Part Number Key
1 Post
fixx
Its guys like you that hide behind their keyboard making smart azz comments to pizz off people like me....
ok back to the trand and sorry for the cork screw..
Excuse me?? i dont make it a habbit of calling myself a pro engine builder............sorry i mistook the letter in question and yes i use the hk bearing in the race engines with the alunimum rods...ALL the pro engine builders i know wont use a h style bearing on a cast crank PERIOD...
Excuse me?? i dont make it a habbit of calling myself a pro engine builder............sorry i mistook the letter in question and yes i use the hd bearing in the race engines with the alunimum rods...ALL the pro engine builders i know wont use a h style bearing on a cast crank PERIOD...
Force, when you say you are using the H-series, are you running the HK, or just the regular H? Apparently there is a misconception as to which ones actually have the graphite coating on them. They have to have the "K" suffix on the part number to be coated. FWIW, my engine builder replied and said that he always runs the regular H-series bearings and has never had an issue with them.
I am a firm believer since I have had water contamination and they saved me, that extra coating helps when things go bad...regular is also fine, but I have the preferance of coated since thay have saved me a crank...
If you order a rotating assembly from just about anywhere, if you get a cast crank, you don't get H series bearings. Forged cranks, you do. Cast come with P series, standard King, etc. Forged come with H series, King Alecular race bearings etc.
http://www.flatlanderracing.com/scatsr-chevybbcast.html
http://www.rpmmachine.com/scat-strok...0hp-2pcrs.html
John Lingenfelters thoughts on this....
http://books.google.com/books?id=GUC...kshaft&f=false
