572 talldeck fit ment in older icbm
1 Post
fixx
standard deck on the ole engines are 9.800..tall deck is 10.200 all the way up to 11.100+ depending on the mfr..so it could vary depending on what your deck height is..
Registered User
rob,whats the center to center distant between your drives?my distant between my drives on my 10meter is 33"which is tight.i had to have spical manafold made to fit.
Check your center to center measurement. Fitment will depend on a few things. The specific cylinder head you are running will have a big effect. Most aftermarket heads have raised exhaust ports. Most are in the .400-.600 area. The exhaust itself will also effect it. I can tell you this much. A pair of tall decks, with .600 raised port heads and E tops needs at least 34" center to center to fit side by side.
Eddie
Eddie
Rob,
AlsolLook at this thread, I think 88 bullet put tall decks in, tight fit.
http://www.offshoreonly.com/forums/f...e-restore.html
