Let's talk thermostatic oil cooler sandwich adapters! >
Old 02-12-2014, 07:20 AM
I'm thinking of using this one, anyone tried one of these?
http://www.hardin-marine.com/p-26867...k-adapter.aspx
launchpad475 is offline
Old 02-12-2014, 02:52 PM
MER Performance's Avatar
Buying one for a 383 EFI build, I'am doing. It's basically the same as Mercs, no modifications if you buy Hardins.
MER Performance is offline
Old 04-11-2016, 05:42 PM
Originally Posted by Budman II
Hmmm - no one wants to talk about them, huh? Boring subject, I guess. :P Surely someone is out there running this adapter. I would try to call someone in their tech support to ask directly, but I might have to brush up on my Mandarin Chinese first.
Originally Posted by Rookie
I have them and I think I gave you the link to Jegs for them. They are set to open around 180*F. I think for the $26 price they work great. And after hard runs and an elevated temp of ~230*F, with the Mobil 1 V Twin 20w50 I run I couldn't be happier. My bearings show it in my Preparing for SuperChargers thread. Minus where something went through the oil system.
This is an old thread , Rookie what model is it if you don't mind me asking
JMPH is offline
Old 04-11-2016, 07:12 PM
Rookie's Avatar
Received 1,207 Likes on 580 Posts
I'm pretty sure this is the adapter.
http://www.jegs.com/i/JEGS-Performan...ductId=1032937
Rookie is offline
Old 04-11-2016, 07:27 PM
1/2" hole okay for a oil cooler ? I'm contemplating going with an earl 504 , what to you think?
JMPH is offline
Old 04-11-2016, 07:33 PM
JMPH is offline
Old 04-11-2016, 08:05 PM
Rookie's Avatar
1/2 FPT (NPT) is 0.804" inside diameter. No opinion on Earls don't know them.
Rookie is offline
Old 04-11-2016, 08:35 PM
Jason .....What did you use for lines and fittings? The brass barbed fittings that come with it and stainless clamps with rubber hose? Setting one of these up now and was wondering if that is sufficient.
picklenjim is offline
Old 04-11-2016, 09:17 PM
Rookie's Avatar
I use AN fittings, I believe -12. My oil system is plumbed with stainless braided hose. I also ground all of the sharp flash inside of the thermostat and put a radius on all of the sharp corners and edges to reduce shear. I also drill out my fittings a little.
Rookie is offline
Old 04-12-2016, 08:18 AM
Anybody use earl model 504 ?
JMPH is offline
