Has anybody ever had Red Loctite fail?
I dont know what they used,I assume it was red,blue? but steel allen head bolts bolting a shaft to aluminum plate ,it looks to be 3/8,but its metric.
Wonder what temp will make red locktite fail?
When installing the fastener Loctite is also a lubricant so you need to torque the fasten as a lubricated part vs. dry. Look at a torque table that shows both dry and wet torque. Their also are primers for Loctite.
ed
ed
thread locking compounds are NOT what are used to hold the parts together. they are the last line of defense for vibration and shock and are never considered as part of the " design" in a hardware solution. if the bolt fell out its not because " the locktite failed" . the locktite wasn't supposed to be holding it together in the first place. if it fell out there was something basic wrong with the way it was installed or with the hardware selection or concept in the first place... i mean, think about it... using a grade 8 allen head in a piece of theaded al.. thats probably a 160,000 psi bolt that requires significant stress to stretch it to preload... are those al threads going to tolerate that without yield ? and what happens when the al warms up and expands while that piece of hardware grows about 60 % less ? it looses its preload... thats what. you can't glue your hardware in to compensate for a bad installation and then when it fails blame the glue. thats like blaming the oil pan when the connecting rod is laying in the bilge
Used as cylinder sleave set! That will get the job done. To the OP...sounds to me like they didnt torque the bolts properly.
As someone mentioned earlier, use the loctite brand. I have had small set screws come loose in a high vibration situation (snowmobile primary clutch) with other brand products. With red loctite I never had a problem.
