B&m 250 or alum heads? >
Old 03-03-2013, 10:47 PM
Originally Posted by River_Runner
Last year my father and I built a 509 from a gen 6 block we decided to go with the Dart 308cc Iron Eagle heads, with the SRP mini dome pistons, a quick fuel 950, and the dart single plane intake. We made 601 horsepower on the dyno. It made 601 @ 5600 rpm. The motor went in a 1989 Sea Ray Pachanga 22 and we ran 85.6mph and was not satisfied... so we have replaced the dart single plane intake with a Pro-filer Sniper Jr. Intake and have switched heads to Edelbrock Performer Marine aluminum heads. The motor is going on the dyno this week I hope, but if your interested i'll share the new dyno numbers to give you and idea on what you want to do. If you want to know more deals about my motor since its similar to your feel free to ask.
Sounds like a nice build. I'd like to see how the Edel's stack up against the dart 308 iron head. My guess is they would be close.
That's haulin in a 22 pachanga !
MILD THUNDER is offline
Old 03-03-2013, 10:54 PM
I too am interested in the progress of your motor.
Either way, This boat with 600hp is going to be a big step up. From what I've researched I should hit mid 80's were my last boat only did 63.
Decisions decisions.
cp5899 is offline
Old 03-03-2013, 11:01 PM
My 27 with a 509,stock 088 heads , Hp500 intake,carb and cam ran 68mph.. (24p Bravo 4 blade)
Same exact engine setup with a Weiand 256 set at 5lbs of boost ran 82mph.. (28p Hydro P5 5 blade)
Blower setup ran me $2000..
No heads in the world are gonna give you 14mph with no other engine changes....
HTRDLNCN is offline
Old 03-03-2013, 11:48 PM
Originally Posted by htrdlncn
my 27 with a 509,stock 088 heads , hp500 intake,carb and cam ran 68mph.. (24p bravo 4 blade)
same exact engine setup with a weiand 256 set at 5lbs of boost ran 82mph.. (28p hydro p5 5 blade)
blower setup ran me $2000..
+1
Likefastboats is offline
Old 03-04-2013, 06:29 AM
Wow!! That's a serious gain for sure!!
cp5899 is offline
Old 03-04-2013, 07:23 AM
I also have a friend that has a 28 velocity with a similar setup, his boat is for sale at http://www.powerboatlistings.com/view/20204 . I will be sure to relay the new dyno numbers, hopefully there will be some kind of an increase, if anything the aluminum heads are lighter...
River_Runner is offline
Old 03-04-2013, 08:07 AM
Originally Posted by MILD THUNDER
Ive been running various blowers for about 6 seasons now. I haven't had one issue blower related. The engines, start great, idle great, power is awesome.
Reason people are leary of blowers is because they always heard thru a friend about meltdowns. The 100% most important thing with any supercharger, is the tune. If the tune is off, yes, it will destroy parts.
As for your 850 carb, it will be enough if you purchase one more to put next to it. 700HP is a stretch with a single 850 on top of a roots.
Heres a link to my budget builds. 800HP 468's.
http://www.offshoreonly.com/forums/d...oed-today.html
I agree. However if the tune is off on a high compression n/a motor it will destroy parts quickly as well. Some say a blower will show problems sooner. In some case yes, but again only compared to a low performance engine.
You also only hear the bad, not the good of guys out there running all the time with no problems.
4bus is offline
Old 03-04-2013, 08:14 AM
eddie's Avatar
Originally Posted by cp5899
How is the reliability with a blower? Would my 850 Holley work with the setup?
I've every thing except intake if you want to go the 250 route. A pair of Holley 850's, fuel rails, air cleaner and linkage.
eddie is offline
Old 03-04-2013, 10:28 PM
blkhorse's Avatar
interested in just selling rails,air cleaner and linkage?
blkhorse is offline
Old 03-05-2013, 06:36 AM
CP, my buddy Tim (posts on here as "BadDog") was running a 250 and a big, non-dominator Holley on his 509 a few summers ago. He was gettin low 80's in a Baja Force 235. He sent the carb out to Dean Nickerson for tune and setup, and bought a custom roller cam from him that was designed for the blower. The rest of the engine was pretty much stock 502 like yours - stock unported 088 heads, Lightning headers, etc. He went through a couple of iterations with that build - first he hammered a rod bearing out of it, and later he broke a connecting rod and sent it through the pan. He did put a lot of hours on both motors between builds with hardly any problems. This last time he decided he was done with the blower and built an HP 500 clone out of it. He is running about 72 GPS with it now. He will be the first to tell you that he misses the punch that the blower provides, but if you want to play, be prepared to play. Basically, you can claim all you want that you will run go easy on it, mostly cruising, blah blah blah, but as Tim famously put it, "if you had a 12-inch schlong, would you only use 6 inches of it?"
Tough choice, but you also have to consider things like hatch clearance, how much room there is in front for pulley clearance, etc. What kind of water are you running in down there where you boat? Fresh, or salt / brackish?
BTW - did you get that link for the Cometic gaskets?
Budman II is offline
