Main bearing bore variance after line hone
#41
Mer Perf, don't let stevexm get you going. He likes to debate and you will surely tire before he does. There really is no point and you will just end up POed for no reason. Pretty much what I was alluding to earlier. I surely appreciate you sharing your insight into the machine work tricks of the trade and would like to see it continue. A word to the wise is sufficient...
Lets let Budman II, get back on subject of his thread.
#42
Update
Took the block to the machinist who worked on it originally on Friday, and he got out his Sunnen bore gauge and checked it with me watching. He measured it at 2.9375 or thereabouts, and it got a bit looser on the last couple of bores, but still within spec according to his gauge.
For grins I took it to another shop who is closer to my work - they do a lot of engines for local drag cars, circle track, and occasional truck pullers. He also used a Sunnen gauge, and measured it out on the small side for the first couple of holes - I believe he got 2.936 and some change. He thought that would be a bit too tight, and I will admit that I was concerned that I was showing around 0.0026 bearing clearance on the front two mains. His measurements showed it going large towards the back of the block as well.
I decided to go ahead and spend the money to have him line hone it again. He said he would take the very minimum needed to clean it up, so hopefully I will be able to avoid having to go with a smaller timing chain.
Going to check rod clearance while I'm waiting on the block. Hopefully I won't find any surprises there. It would be nice for something to go right on this build for a change.
#43
Mer Perf, if it makes you feel any better I just rolled in the door from 15 straight hours of union negotiations (debating)..... It blows there too. But tomorrow we will go again.
#44
FWIW, I rarely get away with just one set of main or rod bearings. In my experience if you want it right you have to tailor each individual journal fit to what you desire. So I wouldn't say things aren't going right for you, its just hard to get it precise and consistent across all parameters. Keep us posted on your progress.
#45
Was measuring rod bearings last night and got 0.0029 on #5 and 0.0030 on #6. Remainder measured .0026 or .0027. The journal for #5/6 did not measure significantly smaller than the rest. Do I have a problem here? Wondering if I am going to have to have a couple of rods resized.
#46
#48
Budman, what state do you live in? Years ago REICHARD racing in Owosso Mi did EXACTLY the same thing to a Merlin block I had except the front to rear main cap bores had a variance of .0025 from loosest to tightest . After being blown off on the phone I took block back to them, they kept it inside all day to measure it (was cold when I dropped it off) , I came back and they claimed they only measured it and there was nothing wrong.They really screwed me a second time, after that the mains were then also OUT of round because they re-cut the caps in a attempt to bandaid the mess they created, and stuck them back on. It took alot of pizzing around from my current machinist to straighten it out. I feel your pain on this, nothing better than having a machinist try to tell you that the resulting loose clearances would be good with disregard to the fact that all proper register/crush of the bearing shells would be close to nothing, Bob Madera summed it up pretty well, Smitty
#50
The Latest
Got the block back Saturday, cleaned it up and blew out all the passages. Tonight I finally got the chance to torque the caps down and measure things. First I measured the bores, and got within .005 of the spec of 2.9375 across all the mains. Sounding good so far. So I proceeded to install the bearings and check the clearances on these. Now I am getting .0015, .0015, .0012, .0020 from 1-4. Gave up and didn't bother to measure the rear main as of yet. CRAP!
I guess I'll be hauling my block and crank back out to have him double check the clearances. If my measurements are in the ballpark, I am definitely too tight for a performance marine engine. So how is this issue corrected if I do in fact have an issue? Will I have to buy a set of thinner (more clearance) bearings? I don't want to cut on the crank journals if I can avoid that.
This just doesn't make sense. I am running the stock bearings and my main bores are all in spec now. The only thing that could be off at this point would be the main journals being oversize, but I was measuring 2.7493 across the front four main journals.
Temp in my garage was only about 40*. Could this be affecting my measurements?
