hi-performance 320 EFI
hello new boat owner
Bought a liberator 211 with a merc 320 efi whit alpha drive . and last summer i only got 4200 rpm at wot. have 14.5X21 steel prop. Read that they should rev about 5000-5400 Wot. someone who has experience with this engine, and what can cause these kinds of problems?
Are you having any problems other than low rpm? Liberators are pretty heavy boats if I remember right, If no problems I would try a 17-19 pitch prop. a 19 should put you around 4600 a 17 should put you right around 5000 rpms. Just a thought, Randy
A 211 should be able to pull a 21 no problem, if it's a known good prop. Do you know the prop is good? My 87' 211 would turn a 21" prop to about 4600, and a 19" close to 5k, which was to high for my motor. This was all with the 350/260 about, 52-53mph. What is the ratio of that drive? That's a great motor and should put you on par with the 454/330.
211's Love the 21" ballistic prop.
I had an '86 272 LS Formula with twin 320 EFI's on Alpha SS drives...1.5 ratio. With 23" Cleavers RPM was in the 5800~6000 range!!! One of the fastest boats i ever had. I ran the bejeezus out of those motors and sold the boat with 300 + hours on it. It ran 75 the day I sold it....wish I still had it.
It very well may be a tired old girl.
