milky oil
Old 04-27-2013, 08:06 AM
Ken N's Avatar
Arrow milky oil
Got milky oil what the best way to flush it out.
Ken N is offline
Old 04-27-2013, 09:12 AM
Change it 2-3 times running it 10-15 minutes in between then just run it as you would normally keeping an eye on it.the heat will evaporate the little water left in no time
Rbesola is offline
Old 04-27-2013, 10:55 AM
Expensive Date's Avatar
You can use cheap oil for the flushes, do the filter too. You did find the problem right? Also let it drain overnigt before you put the good oil in.
Expensive Date is offline
Old 04-27-2013, 05:06 PM
Ken N's Avatar
yes I found the problem
Ken N is offline
