Erratic Vaccuum readings >
Old 05-06-2013, 07:50 PM
Originally Posted by MILD THUNDER
Does the engine sound like its missing at idle and shaking? Or is it just revving up and down like blower surge?
Missing, for sure I can feel each header tube and the front two are cold and I have spark.
Seahawk 2000 is offline
Old 05-06-2013, 07:51 PM
Originally Posted by mrv8outboard
Restricted exhaust?
Checked headers, all OK.
Old 05-06-2013, 07:53 PM
Is this a new build? Maybe a lifter (or several) adjusted too tight. When they pump up, the valves are hanging open. Or broken valve springs
Checked all valves and compression is good.
Old 05-06-2013, 07:55 PM
Originally Posted by GPM
2 cylinders firing out of order, spark plug wires are on wrong cylinders, still idles, vacuum dances all over the place, power is down pulling out. just a guess.
Wires are correct and swapped with other good motor.
Old 05-06-2013, 09:43 PM
Not much more to check Maybe the front carb is screwed up causing those cyls to either run lean or flood? seems to be a very odd set of symtoms. keep us posted
abones is offline
Old 05-06-2013, 10:12 PM
GPM
Float needs adjusted, carbs over flowing, just a thought.
GPM is offline
Old 05-06-2013, 11:17 PM
Typically when a vacuum gauge is erratic, there is a problem in the valvetrain. Either a rocker is out of adjustment, a lifter has collapsed, pushrod out of the rocker, etc. Pull the valve covers and start looking. I would bet that you will find your problem.
Eddie
Young Performance is offline
Old 05-07-2013, 12:59 PM
Swapped carbs with good motor, no change
Old 05-07-2013, 01:00 PM
Swapped carb with good motor, no change.
Old 05-07-2013, 01:33 PM
Eddie
Compression is good and I checked and adjusted the valves.
Remember, it starts out with a good idle and go's bad.
I noticed a tiny drop of water on the spark plug when I pulled it out so I pulled the header and there was small amounts of water in each pipe (tea spoon). I'm thinking it was reverting water when the idle dropped down lower. So I swapped headers with the good motor and same bad idle. Could it be that there is a crack or blown head gasket that when the cylinder warms up the crack or leak opens and lets moisture in and shuts down the spark plug.
