Dry exhaust
I had some reversion, especially with the mufflers closed, plus my 02`s were dying a quick death.
I was just going to do a single nipple out the back until Mild Blunder mentioned running most of the water overboard and just small nipple to keep the mufflers from getting too hot.
Much better idea and will keep the 02`s dry
The bung is in the bilge
having the same issues with my lightnings, kills the 02's in mins...went thru 3...question is how little water will can you dump and not have a issue with the headers ?
Stellings would be my only choice. buy therm once and never look back...it is probably the best investment you can make on a performance engine. Remember loud pipes save lives.
buy a set of used stellings or cmi sport tubes and never look back. if your worried about leaks, have them pressure tested. it's hard to justify 7-10k on a new set of exhaust for most people, in fact, it may be worth more than some peoples boats lol. the dumps are at the very end of the pipe and will mix just fine with mufflers if you decide to go with the. i would just leave them off
